VS10+ - Joining Clips
TrevorS
Post by TrevorS »
According to the User Manual (in section Split by Scene), I should be able to join any number of clips into one - "Simply select all the scenes that you want to join together and click Join." I cannot find any "Join" to click. I am new to this so it may well be right in front of my eyes. Thanks for any help.
Firstly take a look at the Tutorial
From Camcorder To DVD I am still working on parts of it but this particular section has been completed.
In Part 3 you will find
OK here I am splitting clips so this picture may not be that clear, but look closely and you will see "Join". to use this you click a clip to be joined to the one preceding it and then click the join button.
TrevorS
Post by TrevorS »
Thanks for your quick reply.
I am afraid I did not follow your tutorial in that I did not create a Production Library for my project. I can't see how to bring up the Scenes page. Should I start again?
You should have a thumbnail of your video somewhere even if in the default video library.
In the tutorial I suggest using the Library Manager to create a separate library for all clips appertaining to a particular project. You can do that at any time - its not compulsory - just a piece of practical advice to keep things organised and tidy.
TrevorS
Post by TrevorS »
Thanks Steve. Can now do what I want (all be it a bit slow).
middlebury madness
Post by middlebury madness »
I have a question re joining. Can you only rejoin clips that physically reside next to one another in the original clip? I have a situation where the old analog video recorder was on the fritz and kept cutting out. In editing I want to cut out the garbage it left between good clips. It did this twenty times in 3 minutes. that leaves me with twenty small clips I would like to treat as one. Is that asking the impossible? I thought I might need to possibley make separate projects then put them back together. I am looking for the simplest method as I have a few more of these things in fornt me.
Your turtorial was very eye opening.
Carol,
The easiest method is to use the Storyboard view and drag the clips to the thumbnials like this
You can re-arrange the order of the clips by dragging a clip with your mouse.
You can also insert transitions (Where the blue arrows point)
middlebury madness
Steve,
That is what I am doing it is that I have twenty of these things and I have to be careful not to mixt them up...
Thank you
Carol M
Carol,
Take a look at what us 'old uns' had to do a few years ago!
http://phpbb.ulead.com.tw/EN/viewtopic. ... 6586#76586
