It's an old thread so probably the problems were fixed in the meantime (sounds as if some s/w is interfering with each other), but to the question of reading the ISO files: I can do so by using the free Daemon virtual DVD drive (www.daemon-tools.cc) - when you mount the iso file it will become a virtual DVD drive and (depending on settings) automatically start playing the disc.
Burning on DVD of course can be done by many tools, such as Nero Burning ROM.
video/audio sequence glitch in generated DVD
David Mears
I'm afraid not yet.deklerkt wrote:It's an old thread so probably the problems were fixed in the meantime
An update . . . I installed the Daemon tools SW mentioned and was able to successfully "play" the entire .iso file gen'ed by DVD-WS, so it appears the .iso file is good and whatever corruption is happening occurs between the .iso file and getting burned onto the DVD media. As my next experiment, I swapped out my DVD burner for my older 2.4X burner, burned the DVD again with that HW and it had the same problem as before. So it appears it's not a hardware (DVD burner) problem.but to the question of reading the ISO files: I can do so by using the free Daemon virtual DVD drive (www.daemon-tools.cc)
David Mears
I downloaded the Trial version of Nero-7 which would allow me to burn the ULead .iso file out to a DVD and that worked just fine. The test DVD+RW I made played without error on the PC, and then I burned a DVD+R copy which I could then play OK on my DVD player. So it definitely looks like a problem relating to the DVD-WS code trying to burn the .iso file to DVD.sjj1805 wrote:Only one thing left then.... burn the iso with another program and see what happens.
I'm now a bit suspicious of the "burning engine patch" I was directed by ULead to install from http://www.ulead.com/tech/general/burning_patch.htm when I reinstalled DVD-WS 1.2 due to an earlier problem, since the part of the code which appears to be failing sure sounds like the "burning engine." I have uninstalled and reinstalled DVD-WS without reinstalling this patch, though, so I don't know if this patch might have installed files which don't get uninstalled via the DVD-WS uninstall process.
Is there any way to remove this patch and return to whatever "burning" code I originally had (assuming that it isn't being removed by unistall DVD-WS itself)?
- ram: 2 GB
- sound_card: Intel GMA 950
Looking at the DVD Burning patch web page I see the following:
Who can update:
Who can update:
- * Ulead DVD MovieFactory 3.0/3.5/4.0
* Ulead DVD WorkShop 1.X/2.0
* Ulead DVD PictureShow 2.0/3.0
* Ulead VideoStudio 6.0/7.0/8.0/9.0
* Ulead Video@Home 2.0
* Ulead MediaStudio Pro 6.5/7.0
* Ulead Ulead Burn.Now 1.X/2.0
* Ulead Photo Explorer 8.0/8.5
David Mears
Yeah, I noticed that too, which led me to believe it probably goes into some "common" area.sjj1805 wrote:Looking at the DVD Burning patch web page I see the following:
I think it also suggests that merely purchasing and installing DVD-WS 2.0 would not be a fix for the problem, as the patch seems to impact WS2 as well.This tends to suggest that removing DVD WS will not remove the burning patch.
I have a reply back to ULead support; I'm hoping they can tell me how to remove the patch code from the "common" directory(es) and reinstall the original code from one of my original install files (I have my original downloaded VS6 and WS1.2 install files, as well as VS9 on CD).
David Mears
Now I've got yet another problem.
Now that I have at least a temporary way to burn created disc images, I put together the second set of episodes for the TV show I'm trying to transfer from tape to DVD. I got everything built and was trying to create the ISO disc image from WS when it gave me an "Unexpected Error." Looking in the ~DVDPrjConvertLog.txt file, at the end, it says
I've once again tried uninstalling DVD-WS and reinstalling per previous instructions, and have completely recreated the WS project from scratch (saving only the captured MPG files to build it from) but I can't seem to get rid of this problem.
I seem to recall having a problem like this once a long time ago but now I can't recall how I finally got rid of it. I thought it might've been by removing the project (and all of the cruft in the project folder) and recreating it from scratch but that isn't working this time.
That folder actually does exist now, but it doesn't seem to matter if it does or not, I always get that error in the log.**[DVD:FAIL] Fail to generate new vob folder C:\Documents and Settings\Owner\My Documents\Ulead DVD Workshop\Trax\~f\, cache vob folder resets.
David Mears
I have a new update, and this time it's good news!
Somehow, in all my uninstall/reinstall (etc.) changes, my "capture" settings got set to use 44.1kHz for audio frequency instead of 48kHz. As long as there was any video within the project with 44.1kHz audio, the failure would occur. Using VS I re-edited the files to use 48kHz instead and things worked just great after that!
If anyone's maintaining an FAQ for problems, they might want to note this one! It sure was an odd one (with no suggestion in error messages anywhere that it related to audio frequency).
I found the problem! Or, at least, I found what was causing the problem.David Mears wrote:Now I've got yet another problem.
