I receive an Unspecified Error 5:0:0 when I try to burn a DVD with MovieFactory 5.0
Any idea?
Thanks!!
Zek
zek2008
ok......
Properties of your source files:
I captured this from TV in PAL-N formtat
Output format :
MPEG files
24 bits, 720 x 480, 29.97 fps
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 224 kbps
I try to change some settings of the output but I still got the error.
Error Codes
I try to create to disc, create DVD folders and Create disc image, but when it finish to render I get the error.
I f there is any other information you may nedd please fo no hesitate to ask.
THANKS!!!!
Zek
Output format :
MPEG files
(DVD-NTSC), 4:3
Error Codes
THANKS!!!!
Zek
maddrummer3301
zek2008
I capture TV on PAL format and then I need to create a DVD in NTSC format because almost all DVD players in my country work on NTSC format. The TV format of my country is PAL-N
I´ve done it in the version 3 of Movie Factory and works great...then I bought the version 5 because all new features that I read in the Ulead page but I can not do the same thing I made with the version 3 of MF.
The error message appears when the soft has to start to burn on DVD or create folders on disc....and you may notice that the description of the error is not very descriptive
Any suggestions???
Best regards,
Zek
Any suggestions???
Best regards,
Zek
