Error Message: An attempt was made to access an unnamed file past its end.
What's causing this error???
i was in the middle of the my project and it froze in the slideshow settings, all my pictures are still there but when i try to go to the slideshow i get this error and i can't do anything.
any ideas???
Error Message: An attempt was made to access an unamed....
- michaeltee
- motherboard: HP 82F1
- processor: Intel Core I5 7400 3 GHz
- ram: 16 GB DC
- Video Card: Intel HD Graphics 630
- Hard_Drive_Capacity: 2TB Hybrid
- Monitor/Display Make & Model: Samsung S24D300
- Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Re: Error Message: An attempt was made to access an unamed.
Hi Tanya,tanya wrote:Error Message: An attempt was made to access an unnamed file past its end.
any ideas???
Ulead Tech-Support recommends a clean install to correct this error. Scroll through the following thread and you'll find the procedure. It's a bit of a pain but definitely worth a try. Please post back with your results.
http://phpbb.ulead.com.tw/EN/viewtopic. ... ht=unnamed
Good luck
-Mike
mrsa1113
New help with old problem
Help! I just purchased Pictureshow 4 a couple of weeks ago and worked fine until today when I started getting this same mesage about an unnamed file. It happens when I am editing the audio & effects. I found the instructions to do the clean reinstall and was going to try that, but when I went into my control panel to remove/uninstall pictureshow, it's not there! How do I uninstall it if I can't find it in the add/remove programs part of the control panel?
Kathy
Kathy
- michaeltee
- ram: 16 GB DC
Re: New help with old problem
Hi Kathy,mrsa1113 wrote:Help! I just purchased Pictureshow 4 a couple of weeks ago and worked fine until today when I started getting this same mesage about an unnamed file. It happens when I am editing the audio & effects. I found the instructions to do the clean reinstall and was going to try that, but when I went into my control panel to remove/uninstall pictureshow, it's not there! How do I uninstall it if I can't find it in the add/remove programs part of the control panel?
If the program doesn't appear in add/remove programs (mine is listed as "Ulead CD & DVD PictureShow 4") try reinstalling it (overwriting your existing installation) and then reboot your computer. This should restore the uninstall option. You should then be able to run the uninstaller from add/remove programs and proceed with the clean install procedure.
-Mike
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
Ulead Programs uninstallation procedure
blackqueen
I have recently encountered exactly the same problem. I have followed the very precise uninstallation procedure to the letter and then reinstalled. I have the same problem. As soon as I install a file into the Movie Wizard (I want to add text and titling etc) I can get the file into the timeline but as soon as I click Next to get to the next level and the effects, the program stalls and then comes up with "An attempt was made to access an unnamed file past its end" and Ulead jams up and I have to use the Task Manager to close it down. It has rendered my program unusable... not happy!
It all worked fine before. Now I can't do much with it at all. Has anyone any other solutions before I bin it?!!
