recode again?
Makako
recode again?
Post by Makako »
Hi, i was doing a encode in tmgenc, with 720x480 ntsc, etc...when i put mpeg file in dvd workshop, and send to burn he start recode again the same file, i dont understand since my project is NTSC, why this happen?
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
Which version of WS do you have?
Most have a do not re-encode compliant files box to tick.
Makako
hi
Post by Makako »
the last one... :(
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
In which case tick the box.
From memory it's in the edit section and under the video tab, might be "Don't" tick the covert to disc template box?
You have to ensure the mpegs that tmpg has made are dvd compliant.
Makako
hi
Post by Makako »
thanks from the tip, tell me something...my video it is from vhs capture, 640x480, but dvd workshop do not acept that? i must convert to 720x480? always?
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
This will be why you are re-ecoding then probably, as the file has to be a dvd compliant file and that means 720x480 for NTSC.
Graham
Makako
hi
Post by Makako »
well first i encode in tmpgenc for dvd 720x480, and after i import to dvd workshop, and dvdws want recode again , even in the right dvd template...i still work here, but thank you very much!!!
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
Sorry, forgot that step.
What settings did you use in TMPGenc, and have you ensured there is no tick in the convert to template box?
Makako
hi
Post by Makako »
graham, i am midlle of conversion now, it is 41% in tmpgenc, yes i use dvd tamplate ntsc in that program...and i will test just like you said after enconde this avi finish, tell you later...what happen! lol...
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
Let me know what settings you've used if it doesn't work.
Also, can you get an NTSC dv-avi out of TMPGenc?
If so, it may be best to make that and import it into workshop.
