need to know if this is correct
fc9ii00x5
Post by fc9ii00x5 »
file format : ntsc dvd
video type - mpeg-2 video, lower field first
total frames - 47 frame(s)
attributes- 24 bits, 720 by 480, 4:3
frame rate: 29.970 frames/sec
data rate - variable bit rate (max. 8000 kbps)
Audio type - mpeg audio layer 2 files
layer - 2
bit rate - 224 kbps
i'm trying to burn a dvd to view on my t.v,
is this correct format,
because for some reason
my dvd won't play it, says incorrect disc,
i've authorized the dvd i'm not sure if i did it correctly
i'm using ulead 8.0 pro
if anyone can help that would be great thanks alot
FC
fc9ii00x5
You have posted this in the Tutorials Section.
By 'ulead 8.0 pro ' do you mean MediaStudio or VideoStudio?
I will then move this post to the correct forum so that the experienced users of that forum can offer more help.
My initial thought is that you have simply burned a copy of the MPEG file onto a DVD disc without actually authoring a DVD.
By this I mean creating a DVD Menu and then on the disc you will find two folders:
Audio_TS
Video_TS
In the Video_TS directory you should find files with names ending
VOB IFO BUP
EDIT:
I have now been informed by the Poster that she is using Media Studio 8
and so I have moved this topic.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
It's a mighty short dvd at just 47 frames!!!!
I wouldn't use mpeg audio, try either lpcm or ac-3.
Then check your dvd player will play the discs you have, see
www.videohelp.com/dvdplayers
