I need help
USING VS 8
I have a small annoying problem regarding camera control during capture.
I am capturing to DV-Avi via Firewire from a Canon Mv400 camcorder.
I have reported the fault to tech support who after 5 months tell me it must be my pc as nobody else has reported the condition.
‘Can I try another pc’ was there reply.
I do not have access to a second pc but with the help of the forum I have many.
This is what happens
1 / I set the preferences to ‘show messages when inserting first video clip to timeline’
2 / I set preferences to ‘auto insert transition effects’
3 / I capture split by scene.
4 / Change the project Properties to Mpeg.. Odd request but it will ensure the info box from (1) above will be activated.
5 / I capture to Dv-Avi
Capture is terminated by clicking the mouse ‘stop capture’ or the capture pre-set duration time is reached.
At this point the camera should pause and the clips load to the library and timeline, an info message is usually shown to change the project properties to match the captured video.
This is where it goes wrong:-
My camera continues running until I ok the info windows. The camera will continue to play to the end of the tape, unless I intervene.
When I do ok the info windows the captured clips are inserted to the library and timeline and the camera is switched to stop.
I would expect the camera to be switched to ‘pause’ leaving the preview window showing the next clip to be captured.
CAN YOU HELP
Test your capture process.
Does your camera stop immediately after capture or does it continue to play? if it does it shouldn’t.
If you do find this problem let me know,
talamail2004-forum@yahoo.co.uk
Then I would like you to report it to Angelo Gonzales Ulead Technical Support
http://www.ulead.co.uk/tech/techsupport.htm
I have no problems using video studio 7.
Video Studio 8 is the problem.
I am holiday for 2 weeks from Sunday, I will reply to the forum or e-mails, early March.
All the best and thanks Trevor.
