Adding .exe and autorun (.inf) file to DVD???
CSingleton
Post by CSingleton »
Hello,
I am using MF3 Disc Creator. I need to burn an .avi file to DVD. That is not the problem. What is is the quality when played back on the computer. On the TV it is perfect. I want to add the .exe version of the same show to the DVD with an auto run file also, so that when the disk is inserted into a PC, it will play the .exe, not the movie file. I tried leaving the disk open (box unchecked), then going to the data section of MF3 after the movie was burned, but I got the message the disk was not empty or there was no disk in the drive! It seems to have been finalized since it would also play in my set top DVD player. Then I tried again by adding a folder with these 2 extras included to be burned along with the movie, but it was buried under other folders so the PC did not recognize the autorun file. How can I accomplish this? DVD movie and EXE with autorun file on one disk?
Thank you,
~CSingleton
thecoalman
Post by thecoalman »
Can you create a video folder on your drive instead of burning it, add the file then burn. Or burn the disc, rip it to your hard drive add the file then burn it.
Don't what your trying to accomplish but if your using the same source footage it's going to look the same no matter what you do.
The reason it looks bad on the coputer is it's interlaced, monitors are progressive. They make software which compensates for this, MS Media Player does it but PowerDVD does a much better job. The best IMO.
You could also deinterlace the footage for computer playback only which will look better.
