Strange question... audio stops at the end?
stannmaple
I just burned a DVD and it turned out beautifuly... only one problem. In the last 3 minutes of the video, the audio cuts out completely. It was all one track, it was audio from the original project. There is audio in the original video file as well as on the preview on workshop. It's very odd. I'm hoping it was just some fluke thing and when I re-burn it the audio will be back? What I did was captured the video DV-AVI through movie maker. I then saved it as a WMV (because DV-AVI was giving me some audio problems) I found out soon that WS2 has issues with this format or at least this particular video, so I brought the WMV into video studio and saved it as DV-AVI type II. From here everything worked fine... except no audio, but ONLY the last few minutes of the video... it just cuts out completely. Hopefully this is enough information. Let me know if you need to know anything else. Thanks in advance for the help.
Dann
Dann
stannmaple
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Re: Strange question... audio stops at the end?
Are you saying the dv-avi has no audio at all???stannmaple wrote: so I brought the WMV into video studio and saved it as DV-AVI type II. From here everything worked fine... except no audio,
Dann
Or not???
Did you try my suggestion for overcoming the audio problem with MM?
Graham
stannmaple
I did not try your suggestion. If I can't get it to work, that is what I will do next, but before you had replied to my last problem, I had already brought the WMV file into video studio and encoded it as AVI. Seems to work fine. It is ONLY the last few minutes of video that cut out. The whole AVI file has audio and suddenly it cuts out. Very strange and random.... do you know what it could be?
Dann
Dann
heinz-oz
No idea what exactly it could be, maybe one too many conversions/reconversions? Is the audio cut, like something is missing, or is it just ending sooner than the video? Do you have areas in the video where you would notice an out of sync problem or is it just background noise?stannmaple wrote:I did not try your suggestion. If I can't get it to work, that is what I will do next, but before you had replied to my last problem, I had already brought the WMV file into video studio and encoded it as AVI. Seems to work fine. It is ONLY the last few minutes of video that cut out. The whole AVI file has audio and suddenly it cuts out. Very strange and random.... do you know what it could be?
Dann
stannmaple
no... it's really wierd. The audio is all in sync. I've re-checked it and it plays fine in the original file and the file converted to AVI. There must have a been a problem when it converted to MPEG. I really don't understand why. The audio just cuts out totally. I burned the DVD again and had the same problem. I think I'm just going to try to encode it as an AVI type 1 rather than type 2 because if I'm not mistaken, the type 1 AVI includes the audio track instead of separating it from the video. This is what I understand from my limited knowledge. I'll let you know how it comes out. Thanks for the replies. Any other insight is welcome.
Dann
Dann
heinz-oz
- ram: 2 GB
- sound_card: Intel GMA 950
Could you elaborate on this point please. At the moment the clue is a fault in the original capture.stannmaple wrote:..... What I did was captured the video DV-AVI through movie maker. I then saved it as a WMV (because DV-AVI was giving me some audio problems) .....
Rather than converting to AVI with VideoStudio, try converting to DVD compliant MPEG2. It is going to end up as MPEG2 at the end of the day so converting to AVI is only creating an extra conversion step and another area where errors can emerge.I had already brought the WMV file into video studio and encoded it as AVI.
If you do this, check the MPEG2 file before proceeding to the authoring stage with DVD Workshop.
stannmaple
right. That's what I had thought originally. That was what I tried first (to save as MPEG-2 which made the most sense) Unfortunately for some reason, this gave me the same error as when I had saved it as WMV, so I ultimately decided on AVI, which worked. I've now re-tried it as AVI type 1. I will let you know how it comes out. Thanks again for the help.
Dann
Dann
stannmaple
stannmaple
IT WORKED
It finally worked. I have no idea why, but when I converted to AVI type 1 instead of 2, that did the trick. So, I'm glad it wasn't a faulty capture or I would have had to redo the entire project. From now on, I'll be using video studio which looks like it has more features anyway. Like I said though, this was an old project (from movie maker) and I just wanted to get it on DVD. Thanks so much for all the help.
Dann
Dann
skier-hughes
- Microsoft MVP
- ram: 4GB
Steve,
Just for clarity on the audio problem in his dv-avi.
Movie maker has a known problem which when you use transitions you sometimes end up with an audio glitch when saving as a dv-avi.
The capture can be fine, it is just the resulting save as dv-avi. Saving as wmv doesn't have this problem.
It doesn't affect everyone, in fact I can't replicate it, but my fellow MS MVP and Movie Maker expert Papajohn can.
MS cannot find exactly what is causing it, but we have narrowed it down to it somehow removing frame 27 from an NTSC file. Strangley enough though some PAL people also suffer it.........
It causes an audio glitch which can be a pop etc.
Those that suffer it tend to make their dv-avi, and then make a wmv, start a new project, import dv-avi into the timeline, mute the audio, import the wmv to the audio track and save as a dv-avi, result dv-avi quality and proper sound.
A bit of a faff, but a work around
- ram: 2 GB
In that case the answer is simple. Use a different program to capture in the first place. Perhaps DVD Workshop itself depending upon your hardware.
If it does not support your hardware for any reason
1. View our links to free stuff:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=12931
There is one there named Win DV
2. Download the free trials of Uleads other programs
VideoStudio 10
MediaStudio 8
http://www.ulead.com/download/download.htm
VideoStudio 10
MediaStudio 8
skier-hughes
- Microsoft MVP
- ram: 4GB
Steve,
An obvious answer is to use something else
It's not at the capture stage, just the save to dv-avi stage. Saving as wmv is fine on all PC's.
Probably all is OK with save to dv-avi on 90-95% of pc's, it's just an odd few that get this problem, and is most likely down to the hardware/software/codec configurations.
Graham
Graham
