text and moving path
devo_111111
Post by devo_111111 »
Problem with text. MSP 8.1 (?)
Using a moving path animation in the Title Clip dialogue box. (003)
The title flies in perfectly but stop's only briefly then splits up and flies out again. When I double click on the animation box I get a big box of settings which I assume are the moving path info and there is a box that lets you choose a number of pause settings but they don't have any impact on the title.
I would like to be able to read my title before it disappears.
Thanks folks.... Ian
devo_111111
Heh! Answer my own question again. Lucky me.
In the Insert Title Clip box, animation tab. When you double click the animation you want to use a big moving path box opens up with tons of stuff in it. One of the settings is for pauze. Select the amount of pauze you want then hit the Add box at the bottom. Now you get a new thumbnail of that particular animation, with a new name or the same number but it shows up at the bottom of the list. So you can't see that it is there until you scroll down. That's where I found a bunch of stuff, I had clicked add a lot, but didn't find until now.
But it does seem to be very hard for any changes you make, like removing animation, to have any impact on the text. I found click on Use Title size would remove any existing animation so you could then add a new one.
Ian
