VS10 question
tecstar
VS10 question
Post by tecstar »
Is the dissolve transition the same as in VS8???
I would like a dissolve that looks like a crossfade. The dissolve looks "granular"( try it and you know what i mean).
I believe VS10 comes with 5 DVD menu templates. Can you download any more?
Are there any more on a bonus cd?
Can you use templates from other versions of VS?
thanks.
Post by Black Lab »
The dissolve is "granular" as you say, but there is a crossfade in VS10.
As for your question about DVD templates, you can copy them from other versions or other Ulead products. See http://phpbb.ulead.com.tw/EN/viewtopic.php?t=13854
tecstar
Post by tecstar »
The problem I am having with the crossfade in VS8 is that it doesnt seem to cope with the audio very well.
There is a noticeable change in audio between clips. i have tried fading out/in but cant seem to get it clean enough. i was hoping that dissolve might do a better job.
How is Burgers Crossfade? is it any better?
Post by Black Lab »
I've never used it, as I have no problem with Ulead's. You may want to consider upgrading to V10 though. VS8 had loads of problems.
Post by Trevor Andrew »
tecstar wrote:The problem I am having with the crossfade in VS8 is that it doesnt seem to cope with the audio very well.
There was a problem when using transitions and audio fade in Video Studio 8.
If you used a transition and audio fade-out then audio fade-in the fade-in just did not work. The audio starting abruptly after the transition.
It has been fixed
I think the original fix was replacing two .dll files
Then included in the main patch.
Install the update patch http://www.ulead.com/tech/vs/vs_ftp80.htm.
Think its this one uvs8_patch1_e.exe
This solved the problem.
If the main update does not work i can send the Dll files
Trevor
tecstar
Post by tecstar »
Thanks for that. That link doesn't work.
Could you send me the dll files????
Thanks very much.
Sorry about that, I did not check the link--- try
http://www.ulead.com/tech/vs/vs.htm
then select Video Studio 8
You are best installing the patch
But if i does not work
Where do i send the dll files????????? e-mail please.
Trevor
tecstar
Post by tecstar »
I'll PM you!
