selecting tv channel
jaymac
Having just D/loaded the DMF 5 and trying it out find the TV chanels atotal shambles cant identify bbc1 or arrange the chanels I presume it is only getting them of my tv card so why cant I arrange them as i,2 3 etc.,
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=11379
Please complete your system specifications on your profile page
jaymac
Sorry but I only want to know why you cant select channels properly and info for dmf 4 doesn't help if you have 5sjj1805 wrote:Please view:
jaymac
I am using Nova-T/Win20000 pci I am not asking as yet how to capture nor are any of the updates you advise available for Nova-t so to get back to My question how do you sort the channels out and why is there no reference to this anywhere in the manual. I just expect aproduct to be able to perform the basic procedure of setting up and changing channels.
heinz-oz
jaymac
maddrummer3301
In the capture module click on the "Down Arrow" to show the advanced settings.
Under Advanced setting or Options screen there should be a screen where you can display the TV channels along with the frequencies.
I have that screen on MF5 in the capturing module.
I haven't tried to re-assign the channel numbers but I thought it was possilble to add/delete/modify them.
MD
MD
jaymac
jaymac
thanks Steve I did think that was an alternative wasn't sure if that would work so could you then just drag to quickdrop if you are not going to editsjj1805 wrote:I always do my TV capture with the software used for viewing the TV Card as a TV - WinTV2000. It has more flexibility over the capture - the ability to set the capture settings - adjustments to brightness/contast etc.
Then use the resultant file with Uled to create the DVD.
- ram: 2 GB
If you don't want to edit you still need to author as a DVD if you want to play it in a standalone DVD player. (i.e. making a DVD Menu) Simply follow the steps in the tutorial I mentioned.
If you only view these things on your computer you can just leave them in the MPEG format that WinTV2000 captures them to. Obviously there wouldn't be chapters etc. If you dont author to a DVD.
maddrummer3301
The only options I can see for you trying to capture under MF5 is
Advanced Settings -> Video Properties -> Input Source(tab)
TV System -> Drop-Down Box to select the TV system:
TV Antenna or Cable
NTSC_M
NTSC_M_J
PAL_B through PAL_N
Secam_B through Secam_L1
Maybe you have to change the TV system for wherever you are at.
Of course under the TV Manager you have the correct Country/Region Selected.
MD
TV Antenna or Cable
NTSC_M
NTSC_M_J
PAL_B through PAL_N
MD
jaymac
Ok Steve I have done one purely by dragging the file from win/tv to Quick drop much the same as Roxios drag to disc. initial result looks promising have also done it by converting and burnig with dmf. as I'm not into chapters or god forbid watching on my pc I think that'll do for now thanks for your help
Maddrummer I have no problem capturing a tv channel in dmf its just a useless bit of kit for finding the channel you want to capture
