Anyone know if you can insert a animated gif image into a web template when designing a web page through photo impact 10 ?.
Everytime i try to apply animated effects to text or a image through photo impact 10 it never saves them as a animated gif image,it always saves them as a JPEG file,or when i insert a animated gif image it also saves it as a JPEG image,the only way it seems to work is if i manually go back and edit the HTML code myself.
inserting animated gif images to new web template
You can insert an animated graphic although it won't appear to be animated until you view it in your browser. The main screen in PI does not show animations moving.
1. On the menu, click on Web\ Link Object\ File.
2. Navigate to your animation, click on image, click Open.
3. Use the Pick tool to move your animation into place.
4. If you have already sliced your image, you may need to clear the slicing by clicking on the slice tool, click on Erase All.
5. Click on the slicing tool. Right-click on your image. Select Slice Around Object.
View in browser to see the effects.
[url=http://pircnet.com/]PhotoImpact Resource Center[/url]
[url=http://wwell.net/]Wishing Well Tutorials[/url]
[url=http://pircnet.com/forum]PIRC Forum[/url]
