Convert Step Got Some Problems
pudster
Post by pudster »
SUBJECT: Convert Step Got Some Problems
I am trying out VideoStudio 10 and just created a small 10 minute AVI file which I captured from my analog video camera through a capture card.
When I tried to burn a DVD I receice the following message:
Convert Step Got Some Problems (257:00)
Properties of your source files (format, file size, where did you get it?)
What devices are involved and their mode of connection?
Project Settings ??
Output format (file & DVD)
System information (User Profile).
Thankyou in advance.
jchunter
Post by jchunter »
Welcome to the forum. Thanks for filling out your computer specs. :D
The first bit of information that we need are your captured video file properties. Right mouse on any video clip in your project timeline or library and post the Properties that are listed in the Video section.
pudster
Properties
Post by pudster »
Below are the properties
Microsoft AVI - Open DML
Fr. Rate :29.966 Fr/Sec
650.904 Sec
4711.23 Kps
Microsoft YUV Compression
16 Bit, 324x240
19508 Frames
Compression : PCM
48,000Khz
31248000 Sample
I hope that this helps.
jchunter
Post by jchunter »
Your video properties are not what you need to burn a DVD. It would be better if you recaptured your video with DVD-compliant properties as explained in the top sticky post.
For example, use a frame size of 720x480 (324x240 is non standard and wouldn't display all the resolution that your camcorder has recorded). Since your source video is analog, the Field Order property should be set to "Upper Field First."
The video compression that you need for DVD is Mpeg2 - not YUV. If your capture device is up to it, you can capture in mpeg2 at a video bitrate of 8000kbps. Or you can capture in DV format (Type 1), edit that, then transcode to meg2. Either will work. Follow the procedure in the top sticky post for best results.
boldego
Same error for me
Post by boldego »
Here is the data of my clip
file format: NTSC DVD
file size: 1,170,000
duration: 1821 seconds
Video type: MPeg 2 Upper Field First
Frames : 54,597
Attributes: 24 bits, 720X480 4:3
Frame Rate: 29.97
Data Rate: 5000 lbps
Audio Type: Dolby Digital
Total Samples: 87,442,643
Attributes: 48,000 HZ
Layer: None
Bit Rate: 192
I'm completely new to Ulead. I have used TMPGenc autoring.
boldego
Never Mind
Post by boldego »
Found the answer the audio had to be 224
