Nature of the problem:
Using the Title tab to add text over images, the text appears sharp and clearly defined when adding it in.
However, when I run the project, or render it, the text appears fuzzy, poorly defined, and difficult to read.
It doesn't seem to matter what text font I use, but I am using Cataneo BT font sizes 18 and 24.
Properties of your source files (format, file size, where did you get it?) :
Source files are JPEG photos of various sizes and resolutions, some taken with a PowerShot A10, others taken with a Nikon D70. It does not seem to matter how good the photo is, the text still gets a lousy rendering.
What devices are involved and their mode of connection?
No devices involved. Just JPEG files.
Project Settings
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Frame-based
(MPEG-2)
Video data rate: Variable (Max. 6000 kbps)
Audio data rate: 256 kbps
MPEG audio layer 2, 44.1 KHz, Stereo
Output format (file, DVD, VCD, SVCD)
DVD
Text added over images is fuzzy: VS 7.0 SE
WestbrookNH
- motherboard: Hewlett-Packard 1631 KBC Version 01.33
- processor: 2.30 gigahertz Intel Core i7-2820QM quad w HT
- ram: 8 GB
- Video Card: NVIDIA Quadro 2000M
- sound_card: NVIDIA High Definition Audio 4x
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: Generic PnP Monitor (15.7"vis)
