DVD follders
heinz-oz
Post by heinz-oz »
maddrummer3301 wrote:Hi,
You need to be careful NOT to create a DATA DVD using another software program to burn the dvd.
If you use NERO then start a new project and select DVD-VIDEO. Then in Nero you drag the video_ts folder into the video_ts folder in nero's compilation window.
A data dvd may play in the computer but not in a dvd player for the TV.
When you burn a DVD it needs top be burned as a "DVD-VIDEO" disk.
Also, in the output burning stage of MF click on the "Advanced" or "Options" to access additional burning features.
In that screen there is an option that says "Archive Pictures to CD/DVD".
If your project is very large you may want to uncheck that. The program by default backs up the pictures from the harddisk to a directory on the dvd.
That can cause the total size to exceed a single layered dvd.
I have an external firewire/usb combo harddisk that works well on my laptop. Adding one to your setup will make things much easier.
Hope this helps,
MD
Thanks for your input MD, I beg to differ though, I have created a number of DVD's this way and burned the VIDEO_TS folder as a data DVD using BurnIt.Now and my burn program that came with my Panasonic burner. I have however not used Nero.
Because the DVD is already authored and all VOB, IFO, BUP etc. files are created and contained in the Video_TS folder, why would you need to burn it again as a DVD video file? I certainly don't and it works.
