burning the dwz file
samjesse
Post by samjesse »
using MovieFactory 3.5, under windows 2000, I created a slide show using some family photos and added some music and all, I notice it created a file with "dwz" extension in My Documents\Ulead DVD MovieFactory\3.0\DVD_051116.dwz, now I want to burn the dvd, how is it done?, when I use the copy DVD image/file it does not want to accept the file VD_051106.dwz as a correct format to burn it either using the MovieFactory 3.5 or Nero.
project setting
MPEG files
24 Bits, 720 x 480, 29.97 fps
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 7000 kbps)
LPCM Audio, 48000 Hz, Stereo
DVDDoug
Moderator
Post by DVDDoug »
You're not done yet. You need to click the "burn" icon to burn a disc or create the DVD folders. (I don't think MF can make an image file.)
The DWZ is a set of instructions, telling MF how to construct the final video. With nonlinear editing (NLE) you don't actually edit the original video... You set-up editing instructions, and when you render the editor follows your instructions to make a new 'edited" file without touching/editing the original files.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
samjesse
Post by samjesse »
when I first start MF3.5, there is no burn icon. so I go as follows;
Create slideShow Disc > existing project > Ok > Next "still no burn icon" > Next " I get ULEAD creative Intelligence black window" > Next "I get window titled "Ulead DVD MF - Finish[DVD_051116.dwz] still no burn icon but there is
Record to disk 'checked'
normalize audo 'not checked'
> Options "select by disk burner from the pull down menu"
I now have Output icon ' is this what you mean burn icon ? '
also one prolem. the Required/Available working folder space is 11.8/5.5 gb, I don't have any more room. is there a big problem here?
thanks
