Sorry to jump in again. I downloaded the
instruction manuals for your camcorder.
>On Menu set up screen you say to activate the firewire interface and SET
>(A/V->DV-OUT) Do you mean on the camera screen ? because I can't see
>any reference to this.
There are 4 manuals in pdf format to download. One of them specifically
gives step by step instructions on how to use the pass-thru feature
connecting a VCR to the camera and DV-Out to the computer.
According to the instuctions you MUST activate the DV-out via the
CAMCORDERS MENU SYSTEM.
Also:
The A/V -> DV-Out may not be available if you don't have the external
power supply connected and turned on. The unit will not output DV using
the battery. The external power source must be used.
Link to Sony Docs:
http://www.iq.sony.com/srvs/sosdocs/def ... onysupport
This is the documentation file section: Do not type the "E" in the model
number when searching. I used the DCR-HC20 to find the files.
Hope this helps.
MD
Rookie needs help caturing
Peter Robinson
