I received my boxed ver 10+ this morning. It was mailed out on Tues. the 16th. Not bad!
I could use some suggestions regarding the Working Folder in Ver 10+.
I just put together a new computer with SATA drives, three 400 GB hard drives, Dual digital monitors, etc.
Question -- should I jam all video files into drive C and clone the drive every week, or should I take advantage of the (alledged) SATA capabilities by placing my video files into an external drive in a SATA 2 enclosure which I already have?
For cloning, I use Ghost, and have had great success.
Incidentally, another earlier post mentioned the size of the boxed version Manual. Here sre some manual measurements:
Ver. 8 8 1/4 x 5 7/8 201 pages
9 7 1/8 x 5 218 pages
10+ 6 x 4 3/4 183 pages
Thanks for any help.
Working Folder +Back-up for 10+
Rich2Putt
- processor: 2.9
- ram: 8gb
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: IMac AIO
Re: Working Folder +Back-up for 10+
shoalhaven wrote:I received my boxed ver 10+ this morning. It was mailed out on Tues. the 16th. Not bad!
This is my setup. I have two internal hard drives C & F.
I loaded VS10 on c: drive. I then created a diretory on the f drive called Ulead 10. In that directory are three files, work folder, capture, & iso.
I set my capture to save on f:\ulead10\capture
I set my working folder on f:\ulead10\workfolder
When I burn a DVD, I like to make a backup file, therefore my iso file.
This has worked well for me.....
iMac AIO (late 2012)
Windows 7 (bootcamp)
VS Pro X3
8gb RAM
1 - 1TB HD
1 - 120 SSD
1 - 2TB External HD
Panasonic DVC-30
VS Pro X3
8gb RAM
1 - 1TB HD
1 - 120 SSD
1 - 2TB External HD
Panasonic DVC-30
shoalhaven
F Drive setup
Rich2Putt --
That's pretty much what I did for Ver. 9.
I put all my ULead data files as well as my MP3's on F drive. Worked very well.
Thanks for your input.
- ram: 2 GB
- sound_card: Intel GMA 950
You may be interested in how I have set up my 3 Internal Hard Drive System. The topic is still under construction but this part of it has been completed:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=13421
The working folder and capture folder are the same one.
When you change one, the other changes as well.
I use a separate working folder for each project.
Video Studio 9 / 10 uses a separate working folder for the burn process.
This can be allocated from the preferences icon lower left of burn window.
Changing this does not change the capture/working folder
Trevor
Trevor
shoalhaven
Working Folder & backup
Thank you gentlemen for your input.
Steve, I commend you for undertaking such a monumental task as your tutorial.
Regarding the setup of multi-hard drives, would this be a situation wherein a RAID configuration might come into its own?
The idea of reading and writing in parallel sounds intriguing, but I'm certain there are some disadvantages.
Peace--
Peace--
- ram: 2 GB
You've just reminded me to update the topic in the tutorial Sections!
Please view this debate concerning RAID configurations.
http://phpbb.ulead.com.tw/EN/viewtopic. ... light=raid
Again, thank you for reminding me to paste this link into the tutorial.
