Jerky Playback When Using analog-digital Converter?
StevieB
Post by StevieB »
I am a rookie at all this so it took me hours to learn an important lesson:
Videotape (analog) footage fed through an analog-digital converter (e.g. Canopus) should be treated as digital (not analog) footage -- when establishing settings -- because it enters the computer, through a firewire connection, as digital footage. Therefore, “Lower Field First” is the correct setting . . . not "Upper"
I was feeding wonderfully-preserved 18 year-old JVC VHS-C tapes (been keeping them in a dry, cool basement all this time) and put the capture and burn settings to "Upper" . . . played back great in the computer but jerky via DVD player/TV
Finally dawned on me that I needed to treat the source footage as digital because it's being tranformed as it enters my computer . . . changed setting to "Lower" and plays back perfectly now . . .
jchunter_2
Post by jchunter_2 »
Stevie,
Are you absolutely sure that you did not change anything else - eg capture properties or project properties or BURN properties? Your report conflicts with what a number of other users have experienced... What mocel of Canopus capture box do you have?
John
GeorgeW
sounds right to me...
Post by GeorgeW »
the original post sounds right, and makes sense since the video is being converted to DV .avi's...
George
THoff
Post by THoff »
I have a Canopus ADVC-300, and I can confirm that the proper field order setting should be lower first.
StevieB
ADVC 100 is the model I use
Post by StevieB »
John:
Thanks for responding . . . T and George -- thank you as well.
John -- I have an ADVC 100 hooked via firewire to my computer and and a Panasonic SVHS cabled to the converter via an SVHS cable (and audio cables, of course).
Lower field vs, Upper Field was the only variable I changed. I kept the following settings constant:
4:3
Variable
8000 kbps
720 x 480, 29.97
as well as the audio related variables
OK -- I'm racking my brain on this , , , there's a chance that I left the default speed at '80' during the capture mode while sliding it to 100 during edit mode but prior to creating a video file . .. but that's the only thing I can think of . . .would that explain jerky playback via DVD player/TV? . . .
Steve
rwindeyer
Post by rwindeyer »
I can confirm GeorgeW and THoff's statements. I copy VHS via the pass-through of a Sony DV camcorder. The DV that comes down the firewire is captured Lower Field First.
