why the video file is displaying in slow motion in vs 10+
hamprof
dear friends
i ma using video studio 10 +.
why the video file is displaying in slow motion after it is trimmed and saved the trimmed clip?
your hamprof
bahrain
your hamprof
bahrain
hamprof
out put is slow motion
hi sir thanks for replying
no sir
i just installed the software but still vould you tell me what do mean by that or where can i change the setting.
thanks
hamprof
no sir
thanks
hamprof
Hi Hamprof,
The Playback Speed is located on the Video Attribute Tab, just below the Color Correction button. Click on it, and in the dialogue box that opens up make sure the setting is 100. 100 is normal speed, any value less then 100 slows it down, and vise-versa any value over 100 speeds it up.
THoff
Another possibilty is that the file contents didn't match the frames per second value in the file header. If the file header says the video has 25 FPS, but the video was recorded at a higher frame rate like 50 FPS, then the video will play back at half speed.
What device did the file come from, and how was the file created?
hamprof
out play back is in slow motion
hi sir mr.vidoman
i have caputered alot of videos and i have made alot of fantastic shows but using v.s 8 idid not experianced anything like that> i use a sony video camera model dcr-trv940e
and when installed video studio 10+ with the default setting i got that problem. with the same clip in the time bar and i create a video file then i choose for example dvd 4:3 or any other formate the out put is good and normal but only when i choose to save the trimmed clip the slow motion accurs??!!
hamprof
by the way the out put clips in mpeg formate could not be displayed in adobe premier???!!!
cesare250495
Same problem, not with other software
Same problem.
I'm using a Panasonic DV10000 DV player/recorder for acquiring in DV mode.
AVI files are created correctly.
When I play them in the preview window, the play SLOW (about 4%).
When I put them on the timeline, they work correctly.
When I view AVI files with WindowsMediaPlayer and with other sofwares, they play SLOW.
No such problem with other sofware that I'm trying to leave (Pinnacle) for other problems.
Suggestions?
Cesare
Suggestions?
Cesare
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
Re: Same problem, not with other software
Please fill in your profile so we can identify your system setup.cesare250495 wrote:Same problem.
Suggestions?
Cesare
Can you provide the clip properties and the project properties, please? This would give us a starting point to help identify the problem.
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Guy Lapierre
cesare250495
Ok, sorry for the mislead.
Profile updated.
More details on clips when I'll analyze them (this evening).
The annoying issue is present both with VS9 and 10+, and the settings for AVI capture are not modified from defaults.
The strange thing is that when the clip is put on the timeline, the timeline play works great, as the DVD burned from the timeline!
So I have scenes (avi clips) unplayable with other players BUT on VS timeline.
Cesare
Padova (ITALY)
Profile updated.
Cesare
Padova (ITALY)
AstroMikaku
Regarding Adobe Premier 6.0, if the output format of the video file is in MPEG it will not be displayed properly in Adobe Premier. Adobe prefers AVI (Audio Video Interleave) files and most video editors also prefer either DV (Digital Video) or AVI for editing. All though, agreed, these files are extremely huge if not unmanagable, regarding hard drive space too, but, thats the way it is. Ulead is about one of the only editing systems that allow you to edit in MPEG.[/quote]
cesare250495
Here we are with file details.
File format: AVI Microsoft file (valid)
File size: 33Mb
Frame rate: 25 f/sec
Duration: 9.6 sec
Data rate: 3515.63 kbps
-- Video --
Compression: DV video encoder - type 1
Attributes: 24bits, 720x576 4:3
Total frames: 240
-- Audio --
Compression: DV audio - PAL
Attributes: 48Khz, 16bit, stereo
Total samples: 460.800
It's obvious that I'm using VS in PAL mode and Ulead DirectShow
Capture Plugin
Need other infos? Just ask.
Cesare
File size: 33Mb
Duration: 9.6 sec
-- Video --
Total frames: 240
-- Audio --
Capture Plugin
Cesare
GuyL
- processor: I7 920
- ram: 6GB
cesare250495
Yes, just checked.GuyL wrote:Are your project settings the same?
I've tried to change DV codec (from standard to Panasonic one) without any result.
Another useful info.
If you play with "Clip" highlighted, the speed is wrong.
If you play with "Project" highlighted, the speed is OK.
If you play with another player (WMP, for expample) the speed is wrong.
Cesare
GuyL
- processor: I7 920
- ram: 6GB
I'm confused....cesare250495 wrote:Yes, just checked.GuyL wrote:Are your project settings the same?
Cesare
You say the clip doesn't play and nor does the project. However, in a previous post you said it plays fine in the timeline. Should I assume that means playing a clip that hasn't been inserted into the timeline and the project preview?
Have you defragged your system? It may be a simple performance issue. This seems quite odd.
Guy Lapierre
Guy Lapierre
