Ulead dvd workshop 2.0
bbfemekr
Post by bbfemekr »
Hi all , im using the ulead workshop 2.0 and i have some questions. How i could this?: when i push the stop button, i want to go to the dvd menu, what should i do on the editing ? and when i start from a blank page to create my menu how could i link the buttons with videos?thank you !!!
DVDDoug
Moderator
Post by DVDDoug »
Are you using the demo version? If so, you can Download the User's Manual.
Uh, what stop button? You can link any of the on-screen buttons that you create to a menu. The stop button on the remote? I think my romote has a pause, but no stop.
On the editing page, you drag-in your video clip(s), trim the clip(s), and set chapter points.
In general, you create the buttons first, then you can link them by dragging something onto the button... a chapter from the chapter list, a clip from the time line, a menu from the menu list, etc.
1. Set the chapter points. Advance the video to where you want the chapter, then click "Create Chapter.
2. Create the buttons - Drag one of the standard buttons into the menu, or type-in text to be used as a button, or drag in an image to be used as a button.
3. Drag the item to be linked onto the button.
bbfemekr
Post by bbfemekr »
DVDDoug wrote:Are you using the demo version? If so, you can Download the User's Manual.
Thank you for answer me!
I'll try to do what you say , and i'll let you know later....
bbfemekr
Post by bbfemekr »
Hi DVDDoug, i want to thank you VERY VERY VERY MUCH , these steps(1,2,3) was the best instructions i could get even from the manual, but i have 2 more questions: 1.The loop command how how i could insert it in my project?(e.g. ?). 2.When push the stop button from my remote control (i like to see my movies in my home dvd not in pc) i want go to dvd root or dvd menu - could i do this? sorry if i put you in trouble with my questions - thanks again anyway!!
GeorgeW
Stop Button
Post by GeorgeW »
When you push the STOP button, the dvd usually stops playing (it is sometimes in the shape of a square on the button). Is that the button you want to hit to navigate to a menu?
George
bbfemekr
Re: Stop Button
Post by bbfemekr »
GeorgeW wrote:When you push the STOP button, the dvd usually stops playing (it is sometimes in the shape of a square on the button). Is that the button you want to hit to navigate to a menu?
Yes! could you help me with this?and about the loop command how is it works could you help me too?thank you for answer me :D
GeorgeW
Stop button
Post by GeorgeW »
that STOP button will make playback STOP. I don't think you can control how it works -- have you seen a DVD that works the way you want it to?
Which LOOP do you need help with -- the LOOP for the MENU, or the LOOP in a button Playlist?
George
George
bbfemekr
Re: Stop button
Post by bbfemekr »
GeorgeW wrote:that STOP button will make playback STOP. I don't think you can control how it works -- have you seen a DVD that works the way you want it to?
George
Hi, well you very are right about the STOP button, i was wrong, so this ends here, about the loop - i think need help with the LOOP in the button playlist.
GeorgeW
Loop
Post by GeorgeW »
When you add the LOOP in the button playlist, everything inside the "Loop Start" and "Loop End" points should continually play.
Is it not working for you?
George
bbfemekr
Re: Loop
Post by bbfemekr »
GeorgeW wrote:When you add the LOOP in the button playlist, everything inside the "Loop Start" and "Loop End" points should continually play.
...Well it's my first try to make a dvd so i had some doubt about it.But now thanks to you all gone ok, thanks man!! :)
