I am hoping someone can help or advise ,
I want to be able to create a DVD menu title that will enable the user to Play an entire DVD or select individual chapters which return to the main menu when finished.
As video studio 9 only allows you to mark the in points not the out you have to watch the entire DVD from that start point.
Having read through similars concerns raised by others and it seems the only option is to render the chapters separately and add them in at the share step, my question would be how to do that without increasing the project size if one option is to Play the entire DVD ? i.e can you sew the chapters together ?
I am wondering if Video Studio 10 includes this functionality or if anyone can advise of any other DVD authorizing software that will do the job.
Thanks in Advance
VS9 DVD Menu Title limitation
I don't believe you can do that in VS9 or VS10 (unless you want to edit the DVD Structure afterwards with a secondary software utility).
If you plan to have many "smaller" clips, and want to be able to play a smaller clip and return to menu. Or have an option to play the entire bunch of clips, then Ulead's DVD Workshop can do this via the "Playlist" feature (which allows you to specify which Titles get played for a specific button).
George
George
