Encode PCM to AC3
didierrp
Encode PCM to AC3
I have some video files a little too big for DVD (around 4,6ghz) .I want burn each video on DVD .The files are video Mpeg2 and sound PCM 48 khz.To win a little space I want to encode the sound to AC3 but I don't want to recode the video Mpeg2. Is it possible with MovieFactory 5 ?
Many thanks
Many thanks
didierrp
Yes but are you sure that MF5 don't recode the mpeg2 file during this task??GeorgeW wrote:I would try it with a smaller TEST file in the Trial version (you might only be able to select mpeg audio if Dolby Digital is not in the Trial version).
Add it to the timeline, then hit the EXPORT button, then CUSTOMIZE option. Change the audio to the new format and let it go...
George
Didier
didierrp
How long is your video, how long did it take to generate the new file, and how fast is your machine?
Did the progress bar seem to move along quite quickly, or did it take a "long" time (times are relative to the above questions). But something that takes a long time is usually being re-encoded. Something that encodes rather "quickly" is just encoding the audio.
For instance, on a modern machine, lets say you took a 5 minute test clip. I would expect that to be generated in less than a 30 seconds (assuming no video re-encoding).
George
George
didierrp
maddrummer3301
didierrp
NNNNNNNNNNOOOOOOOOOOOO I hope that I don't re-encode the video Mpeg2 but only the sound (PCM to AC3) it's the subject of my post!!!maddrummer3301 wrote:>>>For 56 minutes of video mpeg2, MF5 take to generate the new file
>>>with AC3 sound about 15 minutes .Computer with centrino 1,8
That's very good time.
Re-encoding the video for a 4+gig file would take hours to do.
You must have a fast Harddisk in that machine.
MD
The test file of 56 minutes is about 2,7 Ghz with bitrate 4,5 and sound PCM .
The computer is a simple laptop Toshiba centrino
didierrp
maddrummer3301
I think you misunderstood.
George & my post are saying that your video IS NOT being re-encoded, only the audio.
Otherwise the conversion would take HOURS to perform.
MD
MD
