Can you play clips in reverse?
sismithin0
Post by sismithin0 »
Hi I just read a Thread about being able to play clips back in reverse, I could not find the thread either. Can you do that?
Also another question is there any web-sites with extra plug-ins for UVS8?
Cheers
Si
burgo
Playing Video backwards
Post by burgo »
If you go to
http://home.t-online.de/home/klaus.horst/
you can download a videotool box that should do the trick
Not tried it yet but it has been recommended on this board
Burgo
Post by BrianCee »
If you use the forum search function you will find that many subjects have been discussed many times
Your question about reversing video clips was discussed very recently here :-
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=903
sismithin0
Hi.
Thank you very much, I have downloaded them but it still does not work??? I am jus wondering does Pinnical studio's have reverse tool??
Si
mosanj
Post by mosanj »
If you don't mind being a little adventurous and feel up to experimenting a little, there are tools to help you do a lot more things than VS8 allows you to. There is AVISynth, a script based frameserver. You may read more about it on www.avisynth.org. Then there is Virtualdub, a video editing tool that produces AVI files - it does not have encoder but there are plenty of tools to improve and enhance your footage. It can be found at www.virtualdub.org.
I have tried these and the results are fascinating.
