Just reinstalled VS10 and I'm noticing that when saving out to MPG, the program consistently crashses right at 99% and leaves two files behind, a new video file without audio, and an audio file withiut video, but no single combined file. It's like it gets to final step and dies.
Saving out to other formats (or at least AVI) doesn't cause this problem.
Any ideas?
VS10 + - Saving to MPG kills it right at 99%
Strange...
Hi!
I've noticed a big "freeze-up" at 99% also, but I left it as it was, and finally it finished up the job. You said that you already re-installed the software, so that would eliminate any software issue.
Does it happen with other programs as well? Is it possible that your hardware has some sort of computing issue? Processor, lack of Ram, etc?
But it is a very strange problem. If you get no answer here, try to contact Ulead Support.
Good luck!
Good luck!
Are you following the Recommended Procedure as outlined in the sticky at the top of this forum?
Jeff
Dentler's Dog Training, LLC
