No video capture device installed
Jim2117
Post by Jim2117 »
I have a registered version 8 of Video Studio and am trying out the Version 10. My problem is that when I try to capture the video off of my Panasonic MiniDV Camcorder (Model PV-GS2) I get a dialogue box which says "Either no video capture device is installed in this system or no device is connected." Version 8 at one time worked with the present camcorder, but now I get the above message. I've installed the appropriate driver from the Panasonic site, and I'm notified my camera is communicating with Windows with a "beep" when I turn the camera on or off. I've tried everything I know. Any ideas?
Thank you in advance.
Jim2117
No special driver should be required if you are using Windows XP and you have the camera connected to the computer via Firewire. Can you confirm that in fact that is how you are trying to connect the camera, and not via USB.
Jim2117
Post by Jim2117 »
Thanks for the prompt reply Ken. I *am* using a USB connection. I'm not too familiar with Firewire. Is it connected to my computer through USB. I don't think I had a Firewire connection when it worked before.....but that was awhile back.
Jim2117
A Thousand Pardons
Post by Jim2117 »
Ken:
Apparently I've lost a few more neurons in the aging process than I thought. After reading your answer and writing my reply, I decided to look for the Firewire port on my computer. So I pulled it out, and there it was...........with a nice, white cable sticking in it that had an end on it that fit the DV port on my Camcorder. Well, kiss my grits if that didn't make the ol' video capture hum. I finished capturing the project and am now going into the editing phase. Sorry for the false alarm. And thanks again for your very prompt response.
Jim
:oops:
Unless you have a pretty recent, high end (i.e. rather expensive) video camera (and I'm not sure that yours fits this description), the USB connection -- even if it is an up to date high speed USB 2.0 connection -- is normally used only for transferring still photos taken by your video camera or else converting your camera into a sort of web camera for the transfer of relatively low quality streaming video. There are only a handful of higher end, expensive video cameras which actually use the USB 2.0 for the transfer of high quality video and I see that VS10 has not been adjusted for capture from them using USB 2.0.
The problem is that camera manufacturers always seem to include a USB cable with the camera, thus giving the user the idea that they should use that cable for everything. But the reality is that if your camera is a mini DV model, then the best -- and for all intents and purposes, ONLY -- way of transferring high quality video to your computer is via Firewire (which may also be called i-Link, particularly with Sony cameras). Basically, Firewire was developed as a (relatively) problem free means of transferring video to a computer at very high speeds. This is necessary since, as you will have realised, video creates very large files and the transfer rate to get them to your computer needs to be high enough for it to flow to your computer flawlessly and without it backing up because the connection can't handle the speed.
The problem is, though, that no camera manufacturer of which I am aware ever includes a Firewire cable. Needless to say, your computer will also need to have a Firewire port into which you can plug the connecting cable. You will need to check whether it does or not. The port looks quite different from a USB port and on the computer would normally be about half an inch long and nearly one eighth of an inch wide, but tapering almost to a point at one end. The Firewire symbol would normally be beside it and it looks like a Y with a small circle where the three arms meet.
But if you don't have one at the moment, the good news is that you can buy a Firewire card pretty cheaply these days (here in Australia they cost only around US$25 -- though you may have to pay to have it installed if you don't feel confident enough to do it yourself). They also usually come with a Firewire cable. Getting the right cable, though, is important, since the Firewire connection on your camera will normally be a small 4-pin one (a bit smaller and slightly different shape to the mini-USB connection). The Firewire connection on the computer, on the other hand, will normally be the larger 6 pin variety. So make sure you ask for a 4 pin to 6 pin Firewire cable.
