I have an animation all messed up but I cannot get rid of the first key frame to start over. Is there a clear way to delete an animation and start over?
Thanks,
Dorked Up Animation
Hi Rngeer,
How do you mean, delete an animation and start over? Do you mean delete the effects added to an object? If so then yes that can be done.
Go to Edit > Remove All and choose either Keyframes or Object Properties. Removing the Keyframes will remove all the animations set for that object. Removing the properties will remove the textures, colors etc.. set for that object.
Hope that helps..
Hope that helps..
rngeer
