I have recently installed this software and find that the Video editor module fails to initialise correctly and ceases to respond. It gets through about 85% of the initialisation but stops when trying to load audio filters. I recall reading somewhere that those filters should be in a particular folder (VIS or something like that) but I cant find such a folder in the program sub-folders. Any help or advice would be most welcome.
By the way, the audio editor and the video capture modules seem OK.
Problem with MediaStudio Pro 7.0 VE
Hi Gary, welcome to the forums..
I just so happen to still have MSP 7.0VE installed. So I had a peek and I find the audio filters under the aft_plug folder.
I didn't have any problems with the install, and have not had any problems with the program starting up.
Have you tried a re-install to see if that may iron things out?
If you do a search on this and other forums, you will find many posts relating this problem and the cure. I believe that it is caused by some third party DX audio filters.
Gary Norton
