How do you combine projects
garana
I 2 edited projects (*.vsp) and need to combine them onto 1 dvd. How is this done in VS9?
Are you wanting them to be just 1 long video, or 2 videos on 1 DVD?
If you are wanting to combine them, so that they are just one long video, then you can do it a couple of ways.
1. Render your first project as an DV-AVI ( or same as project settings). Then open your second project and import the video file you created with the 1st project. Now render that as your DVD-Compliant MPEG2 file.
2. Or with your 1st project open, insert your 2nd project (.VSP). Then render that as a DVD-Compliant MPEG2 file.
Now if you just want to include both as seperate videos on a DVD, then render each project as a compliant DVD MPEG 2. Once that is done, Go to File>New Project. Then go to Share>Create Disc (which is the burning module of VS). Now clicking on the insert Video icon, insert the 2 MPEG2 files that you created. Continue on, adding menus, titles, etc...
There is also the Recommended Procedures, which provide an detail method from start to finish on creating your DVDs..
Hope that helps..
Hope that helps..
Mike-Mat
- motherboard: ASUS P5Q3 Delux
- processor: Intel i7 970
- ram: 12GB
- Video Card: NVidia
- sound_card: M-Audio Audiophile 192
- Hard_Drive_Capacity: 1TB
So I did 4 different projects. I created chapter in the individual projects. When I add them together I loose the chapers and have to re-create them (Add Chapters).
Is that the way it's supposed to be?
It wont use the chapters I already set in the projects?
Mike
Mike
Tips For Manufaturing
Mulltmedia Training For CadCam & CNC.
http://www.tipsformanufacturing.com
Camtasia Studio - VideoStudio X2 - DVDShrink
DVDDecripter - XPPro 64 - Intel Quad Core
ASUS P5Q3 Deluxe MoBo - Panasonic DVX100
garana
Garana
Yes you can, so long as the total size doesn't exceed 4.3 gig for a Single Layer DVD. If it does then we have to think about "Fit to Disc", or using a program called "DVD Shrink", in order to compress it enough to fit....
You might try this, Start a new project, then add a project to it. Check to see if the chapter marks are still there. If so add the second one, and check again, etc... If you do get all 4 projects together with the chapter marks intact, then save this project under a new name, ie; Video combined. Then try to render a DVD-Compliant MPEG2.
I'll pull up my TBYB version, (since it's going to be another 2 wks before I get my boxed version) and see what I can find. But if it doesn't keep the chapters then it certainly looks like a bug, that should be addressed...
No it's not. VS10 + is suppose to maintain the chapters that you set in your projects. When you add the projects together in one project how are you doing this? Are you adding them to one of your 4 existing projects or starting a new project then importing each into it?Mike-Mat wrote:Is that the way it's supposed to be?
