Is there a limit to files in a slideshow
annieambrose
Post by annieambrose »
Does anyone know if you can add unlimited files in VS8?
THoff
Post by THoff »
I'm not aware of a limit on the number of files you can add to a UVS project, but keep in mind that it doesn't really support slideshows per se. If you are adding a bunch of still images to a DVD project and treat them as chapters, then you will bump into one limitation: you cannot have more than 99 chapters with UVS.
david reece
Post by david reece »
99 is the correct answer if you want to have each one as a chapter point.
If you dont want chapter points one must assume endless to 4.37 gb.
The other way is create each movie with 99 chapters in seperate menues. DVDWS seems tocope with this.
