Hello,
Last week i bought a camcorder (HDR-HC3) so i wanted to try ulead videostudio to edit film.
Now the problem:
I copied some DV films from my camcorder to my pc.
When i convert the DV to a MPEG-2 file (7 mbit video, 384 kbps geluid, lower field first, 25 frames) on my harddisk i got no problems, the screen is going smooth.
But when i make a DVD from it with exactly the same configuration it's not really going smooth anymore but it's stuttering a bit.
Because i thought it could be the dvd i made an image from the DVD, but i still got the same problems when i run it from my harddisk.
Anyone has any idear what this can be?
Problem ulead videostudio dv -> dvd
jchunter
See HD Tutorial for step by step procedure for capturing, editing, and creating high definition video files with the HC1 and HC3 http://phpbb.ulead.com.tw/EN/viewtopic.php?t=9854
If you are indeed just shooting standard definition video with the HC3, follow the recommended procedure in the top sticky post. You may not be setting the burn properties manually.
nl1bzw
I was just trying with DV so no HDjchunter wrote:See HD Tutorial for step by step procedure for capturing, editing, and creating high definition video files with the HC1 and HC3 http://phpbb.ulead.com.tw/EN/viewtopic.php?t=9854
Well if it's on auto properties i still get the same problem
jchunter
nl1bzw
nl1bzw
I tried automatic. I tried lower field first. i tried upper field first. i tried frame-based. i tried various bitrates. i tried various different audio.jchunter wrote:Your problem may well begin with the assumption that video property management is "Automatic" in Video Studio - it isn't. Did you set the Burn properties manually?nl1bzw wrote:Well if it's on auto properties i still get the same problem
so almost everything.
the strange thing is that pinnacle doesn't have the problem.
jchunter
nl1bzw
Burned the DVD with exactly the same properties as the MPEG2 file what was running without problems, but it doesn't matter if i run an image from it or if i burn a DVD. The problem is still there.jchunter wrote:If your Mpeg2 video file plays back properly and your DVD does not, you may not have set the BURN properties to match the video file properties. Read the section on setting the BURN PROPERTIES in the Recommended Procedure in the top sticky post.
Already thought about that
