DVDMF 5 Vollversion - Problem with Store
sibbel10
If I provide with full version DVDMF5 a DVD with menus and store the project, afterwards the program closes and then appeals again, the settings to the menu are lost and I must make everything new. With DVDMF4 this went.
maddrummer3301
sibbel10
htchien
Maybe you can try to save your modified menu as a favorite in DVDMF?
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=13130
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
htchien
Hi Sibbel,
Please follow the steps in http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8960 to report your problem so people can understand your issues well.
Also please let us know the DVDMF version you use via the product about box.
If you cannot write it in English then you can try German. I will see if I can translate it in Microsoft Word. However, in English is much better.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
sibbel10
DVDMovie Factory 5
Hi H.T.
sorry for my english. I use Abacho translator. Now my Problem in german:
Nach dem Erstellen eines Projektes zur DVD Erstellung - Menüauswahl, Musikauswahl, speichere ich das Projekt. Wenn ich dann DVDMF geschlossen habe und wieder starte, ist meine Menüauswahl verloren. Es wird immer wieder das erste Menü aus der Galerie verwandt. Das ist auch so, wenn ich ein Favorit benutze.
Danke für Hilfe
English translation by H.T.:
After providing a project to the DVD production - menu selection, Music selection, I store the project. If I closed DVDMF and then start again, my menu selection is lost. It happens again and again the first menu from the gallery related. That is also happen if I use a favorite.
Danke für Hilfe
Danke für Hilfe
Danke für Hilfe
htchien
Hi Danke,
Can you provide the build number of DVDMF 5? You can find it by selecting Preference->About Ulead DVD MovieFactory in DVDMF Launcher or select Settings and Options->About Ulead DVD MovieFactory in DVDMF main program.
My DVDMF 5 version is v5.0.0183.0 and it seems this issue does not happen.
In German (translated by Microsoft Word):
Hallo Danke,
Können Sie die Bauzahl DVDMF 5 zur Verfügung stellen? Sie können es finden, indem Sie Präferenz -> vorwählen; über Ulead DVD MovieFactory in der DVDMF Abschußrampe oder wählen Sie Einstellungen und Wahlen -> vor; über Ulead DVD MovieFactory im DVDMF Hauptleitung Programm.
Meine DVDMF 5 Version ist v5.0.0183.0 und sie scheint, daß diese Ausgabe nicht geschieht.
Hope this helps.
H.T.
Hallo Danke,
Hope this helps.
H.T.
Ted (H.T.)
sibbel10
alles geht
Meine Version lautet: 5.0.0024.0
Das Problem ist gelöst. Ulead Support hat mir eine neue DLL zugeschickt. Sie heißt "umfNormalEditTask.dll". Damit geht jetzt alles.
Good Luck
Andreas
My version is: 5.0.0024.0
The problem is solved. Ulead support dispatched new DLL to me. It is called "umfNormalEditTask.DLL". Thus now everything goes fine.
Good Luck
Andreas
newmediallc
I had the same problem and got the same patched DLL from Ulead support - here is the link and instructions (provided by Ulead) for the benefit of others:
1. Download the DLL file from this link: [Deleted by admin. Please contact Ulead Technical Support for the link]
2. Save the file into this location to replace the old file. C:\Program Files\Ulead Systems\Ulead DVD MovieFactory 5\Ulead DVD MovieFactory 5. You should select YES when prompted to overwrite an existing file for the changes to apply.
Note: This will only prevent the project saving error from happening. It will not recover the lost changes in your project. Thank you
htchien
As I know, the first official release for DVDMF 5 is v.5.0.0183.0, may I ask where did you get the 5.0.0024.0 version?
If it's a pirate version or a version for the press then I think it's possible the version wil have some bugs.
H.T.
H.T.
Ted (H.T.)
deer421
v.5.0.0189.0 doesn't save selected menu
My version is v.5.0.0189.0. And I have the same problem. It doesn't save selected or edited menu for the project. Please fix.
leader
Problems Storage DVDMF5
I have the problem with reload of saved project. The Launcher is starting the load process and than the program crash. The same thing, if you want open a new project, import Video Studio files -> crash.
My SW version is. 5.0.0000.0.
Is this a problem with umfnormaledittask.dll to ?
The links for the *.dll does not work
Please help.
Please help.
