Has anyone successfully rendered a high definition video (HDV 1440 x 1080) file in MovieFactory 5 using the HD DVD format option?
I have used several HD video formats, WMV-HD, MPV, MPEG2, AVI, and AVI uncompressed with the files Burned and saved in a HD DVD_TS folder. When I use the full version of the InterVideo WinDVD 7 to display the rendered files from the MovieFactory 5 created HD disc files, the video is squeezed in the upper 1/3 to 1/2 of the player with the lower portion fragmented with either a color bar, or an image from within the video file.
The HD edited video files that I've tested are fully operational in the WinDVD 7 Platinum player when I open the files directly in the player, when I use coded WMV9-HD format and play from a DVD-5 disc on my workstation, or when I use a AvelLink HD player to view high definition files from a DVD-5 disc, or as a networked video server at full HDV resolution. I have also tested 1280 x 720p sampler files, and raw CineForm Connect HD AVI intermediate files prior to NLE post-production, that produce the same display errors after the HD DVD format render.
My source HDV footage was produced with a Sony HVR-Z1U 1080/60i camcorder, and post-produced with Sony Vegas 6.
The MovieFactory 5 software does not support compressed raw MPEG2 ".mt2" files that are captured direct from the Z1. I have edited my WMV-HD files at 23.985 and all other HD file formats at 29.976 frame rates.
HD DVD Video Rendered Disc Files Issue
Some body has and they are even burning the files to a standard dvd, more info:
http://www.avsforum.com/avs-vb/showthread.php?t=667462
