Hi!
I'm using VideoStudio 10.
Even though I checked the box in project settings for:
Auto repeat when disk playback ends
the created film will not loop.
Now guys, someone somewhere must be able to tell me what I am doing wrong.
Any other settings I must correct in order for it to loop?
Help is needed
Thank you
PhilG
WILL NOT LOOP!
lbigley
Re: WILL NOT LOOP!
I too am having the same problem. I think it may be a bug in the program that needs to be fixed. This feature is important to me, as I'm making a slide show that needs to run all day long. Is there a workaround while waiting for the bug to fix?PhilG wrote:Hi!
Help is needed
Thank you
PhilG
lbigley
OK, my workflow. I am recreating the steps as I write this posting.
I am going to make my slide show print to CD. I go to the "Share" tab and hit "create Disc" The next screen, I change to VCD, as I only have a CD burner. In project settings, I see that the Auto repeat box is already checked, so I hit OK. It also has, do not convert compliant MPEG files checked.
Wait...I just saw something I never saw before...a screen that asks me to name a title page, with a picture of the first picture of the slide show. This didn't happen the many other times I tried to do this.
What I just did differently was...instead of going directly to "create disc" from creating the movie, I opened VS fresh. In the library on the top was a thumbnail of my slide show. I dragged it onto the story board, so now it is just one movie,not separate slides or clips.
Now, I wonder why it worked this time, and not the other way of doing it. I guess this is the workaround that I was looking for. I hope this helps someone else.
Lorne
Lorne
