I saw that this error message is not new. The sollutions i found in the forum does not seem to work...
I can not turn off the quick drop icon at the system tray because there is none...
While burning to dvd folders, i get the error :
The Mpeg program stream is not compatible with this DVD engine
It take's 4 houres to render 50% of my project, my project is 1 hour 17 min.
Properties of your source files (format, file size, where did you get it?) my source files are AVI DV exported with adobe premiere 6.5, with MF 2 and 3 never had problems. If i burn only a avi file with MF5 to dvd folders, there is NO problem.
Project Settings :
i customized Mpeg settings, changed variable bitrate so everything fit's on my dvd disk
Output format (file, DVD, VCD, SVCD) DVD - PAL
output to dvd folders
Error Codes (if any)
error code : 533:-2147216487:0
I already re-installed the program
Please Help, i'm getting crazy of it.
Regards
Joachim - Belgium
