Questions
1 - Can I upgrade from VS9 to VS10 seamlessly?
2 - Is there an upgrade from VS9 to VS10 that woudl be cheaper than purchasing the full product?
3 - Is it worth the upgrade?
Thanks in advance.
Don't hold your breathI'm going to order the boxed version when it's available.
Yes on my system both VS9 and VS10 are installed, but they can´t be opened both at same time. VS10 reads VS9 projects real fine.daddog wrote: What if I download VS10 and have VS9 on my system. Will it let me choose between the two which I use?
You dont ripple edit DVD menus you ripple edit videos on the editor timeline. Both versions of VideoStudio (9/10) support ripple editing.Jamaha wrote:Yes on my system both VS9 and VS10 are installed, but they can´t be opened both at same time. VS10 reads VS9 projects real fine.daddog wrote: What if I download VS10 and have VS9 on my system. Will it let me choose between the two which I use?
I thought the support for saving and defining DVD menu´s on the timeline was the best news, but I am very disapointed that it doesn´t support ripple editing, hence If you have last minute changes to the timeline you have to redefine every single menu pointer.
I have tryed to use Pinnacle VS10 because of this, but it is still way to unstable even after sp10.5.2.
When inserting a videoclip or a effect in a project in between or before other clips, following clip are moved to make space for the new clip.daddog wrote:Ripple editing? What exactly is that?
