Viewing Interlaced Video on TV Monitor
VidKid
Post by VidKid »
Is it possible to use an secondary monitor for checking interlaced video rather than burning to DVD? If so, I could save a fortune in discs - my Panasonic DVD player doesn't like DVD+RW's!
I have a TV enabled as a second screen. It doesn't have an S video port, so it's connected via Video In to the PC's S-Video out. An earlier post suggested that S-Video is only for progressive scan. Is this the case? If it is, how can I get around it?
I have an Imation IMWDVRW16LI burner and a GE Force 6600 GT video card.
Thanks,
Steve.
DVDDoug
Moderator
Post by DVDDoug »
S-Video is NOT progressive scan. That should be a good choice for you. I'd have to look-up the details.... I think it has separated chroma and luminance. I have an older big-screen TV with S-Video input... That old TV doesn't have a clue what progressive scan is! :D
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
maddrummer3301
Post by maddrummer3301 »
Nice VideoCard.
The only way to send a progressive scanning signal from your video card is
you must use the RGB (The 3 analog rgb rca connectors on the external interface block). Then configure the software
to a progressive setting such as 480p, 720p .
You need a HDTV to do this will the 3-rgb analog inputs.
(Actually with the latest Nvidia drivers you can also connect directly to a dvi port on a HDTV and use it). Need the correct dvi cable.
The card your using is putting out a "Interlaced" signal BOTH on the composite
AND on the S-Video terminals. Although according to the instuctions I don't think your supposed to have both connected at the sametime.
To enable a TV connected to your video card using the Nvidia 6600GT and use it in VS 8/9/10:
Goto your Display Properties and click on advanced to get to the NVidia's
Start -> Settings -> control panel -> Display ->Settings->Advanced->GeForce 6600GT
Enable "Dual-View" Mode & select the TV as the secondary device.
Then ((lower down in the selections menu (left-side))
Find "Full Screen Video" and set "Full screen device" to "Auto-Select"
Close and save etc.
Then run VideoStudio goto Preferences (F6)key.
Under the General Tab set the "Instant Playback target" to "Dual Head Device".
Click "OK" and your set :)
NVidia related settings:
Whatever device you have connected as the secondary device in "DUAL-VIEW" Mode will play full-screen.
DO NOT SELECT "HORIZONTAL SPANNING" (da!!)
Hope this helps,
MD
VidKid
Post by VidKid »
Thanks for all your feedback guys. I'll check it out.
Steve.
