edit Q: video from clip A, audio from B?
mikewillnot
Post by mikewillnot »
with VS 7:
I have a project with clips that are from different sources, e.g., the sequence of clips from source A, B, A, etc. The timing is continuous (B is a different camera angle of the same event as A). I'd like the project audio to be from A continuously, while the video switches from A to B to A. Can anyone suggest how to do this? Thanks.
rwindeyer
Post by rwindeyer »
That should be doable. Try placing the whole of clip A in the main video track - complete with audio. Then you can place selected segments from clip B in the overlay track where desired (Motion and Filter - Fit to Screen) and muted.
Hope that helps.
mikewillnot
I've been fooling around (1st time) with the overlay feature, and in VS7 I don't see a way to get to "fit to screen." I also don't see "motion & filters" -- just "motion." Is this where I need to buy vs8?
rwindeyer
Post by rwindeyer »
Ah. Could be. :oops: I have VS8; don't remember how 7 was set up. If you can't see a way to get the overlay to full screen size (muting the audio shouldn't be a problem) you may have to spring for the update. :(
A personal recommendation: VS8 is well worth the update cost, for the extra audio controls alone. And with a copy of VS7 you can upgrade fairly cheaply.
gordon_fan_24
Post by gordon_fan_24 »
another way to do this would be to place the entire clip A, into the timeline, then split the audio from the video. You can then edit the video only, switching from clip A to B. Leaving the audio from clip A in the voiveover track. just make sure you mute clip B, once it is inserted or you may get an echo effect, or 2 audio clips playing at the same time. I have done this many times using VS7, so it should work.
