Is there a way to apply one transitional effect to several clips at the same time?
I try selecting all or several clips, then click on the effect drop down tab, but then they de-select, tried the other way with no success?
Is this possible?
thanks Bruce
Applying transitional effects across several images
In VS9:
File>Preferences>General Tab - check Use Default Transition Effect and choose your transition from the drop-down menu.
Now when you add clips to your timeline the transition will automatically be inserted. (You can't do it to clips already on the timeline.)
Jeff
Dentler's Dog Training, LLC
