I'm trying out VS 10( trial ). I can't find MASK C under transition.
I copied the vfx_plug from VS 9 to VS 10 hoping that it will give me back the mask. I now have the Mask C but the bmp were missing so I loaded them by clicking current and found them under .../sample/image.
I tried it and nothing appends. The path definition are probably not there....
I notice that VS 10 as a path under .../Samples/vfxMask/... but the directories are empty?!?!
Does this get activated in VS 10 after you buy it?( tought that trial was the full version )
Did I forgot to load something after installing VS 10?
VS 10 transition - Mask C
htchien
I use UVS 10 Plus full version and I can see the Mask C transitions in UVS.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
