Missing Items in PI 11
chscott
Post by chscott »
I may be wrong about this, but I thought there was a keyboard shortcut for "Preview in Brower". From what I remember, it was Shift+Ctrl+0
Also, is there anyway I can turn on the old text dialog box that was in previous versions of PI? The reason I want this is, in older versions, you could make the text active, highlight the font selecton box and then use the up and down arrows to switch between the different fonts.
keenart
Post by keenart »
Previewing in a browser
In the File: Preview in Browser submenu, by default, Internet Explorer is already listed for quick access.
ShortCut Key: Ctrl +Alt + O
The Tool Options box has been redesigned so suppose the old is gone. The only way you can see the style of font is to go to the font type box and place the mouse on a font name. Then use the mouse or arrow keys to move up and down to through the selections, and while doing so you get a preview of the look of the font off to the right of the font pane. However, the actual text no longer changes style.
You will probably have to ask Tech Support on help.
chscott
Post by chscott »
keenart wrote:Previewing in a browser
Ctrl +Alt + O does not work anymore for me. It is not even listed on the menu item as a shortcut in PI 11.
Thanks for your response though.
keenart
Post by keenart »
It sounds a though your installation is damaged. Since there is no way to enter shortcut key combinations in PI11 you would have to uninstall, delete the two Ulead folders, and reinstall to get functionality back again.
