Hi All
Im new to this (Video) and the forum, i have had a look around but i cant find what i need - so here goes....
dell dimension 8100 / 512mb ram 40 gig free on hd.
i got a panasonic NV-GS15EB mini dv camcorder. I have installed a firewire card onto my pc ok.
link up the camcorder and pc, fire up video studio8, switch my camcorder to the 'link to pc' option on the dial.
video studio 8 recognises my camcorder and lists it in the source option with dv selected as format.
it also lists the below in the information pane..
infomation panel
uvs050205-002.avi
20x576 dv type 2 pal
01.34.38
panasonic msdv
pcm audio
when i click capture the time clicks over in the duration box at the top but nothing else happens.
10 secs in i get a error pop up saying....
no vieo was captured. please check there is any any
impit signal. there maybe no device selected.
then i clear it and get a.................
pop up capturing failed.
the file is corrupt and unstable and will be auto deleted.
can anyone tell me where im going wrong? I feels like i need click somthing on the camcorder to 'play' the footage, but ive tried most buttons with no sucess and the manual is no help.
thanks for any help and sorry about the long post.
as ever
keen to learn..
help with capture please..
THoff
If you are using Windows XP SP2, you may need the following update from Microsoft:
This update is available from Microsoft here.Update for Windows XP (KB885222)
After you install Windows XP Service Pack 2, some 1394 devices (such as digital cameras that use S400 speed) may not perform as expected.
Quick Info
File Name:
WindowsXP-KB885222-x86-ENU.exe
Download Size:
367 KB
Date Published:
12/17/2004
Version:
885222
rwindeyer
Re: help with capture please..
Just to clarify one point. I'm not familiar with the camera; maybe you are doing the right thing anyway. Usually to capture from a digital camcorder you set the camera to "playback", or "VCR" mode - as if you were going to review the footage in the monitor screen. "Link to PC" sounds a bit like a setting for transferring still images.keentolearn wrote: link up the camcorder and pc, fire up video studio8, switch my camcorder to the 'link to pc' option on the dial.
keentolearn
Hi Thanks for the posts.
i have tried using windv but i doesnt show the camcorder as connected.
vs8 shows the camcorder and the spec in the info box below the preview pane.
i have checked the manual and it appears the dial is set to the correct setting, but i agree i would think you have to press 'play' or somthing to start it playing the tape.
the camcorder shows 'pc accessing' on the lcd screen.
I will keep trying different things, and if i have any joy i will post back here. otherwise if anyone has any other ideas please please let me know know.
many thanks
as ever
keen to learn..
many thanks
as ever
keen to learn..
keentolearn
Hurray!
sucsess at last. (panasonic NV-GS14EB)
1st - rebooted the pc
2nd - opened just windv.
3rd - connected camcorder to firewire cable
4th - put camcorder in record mode
5th - the camcorder view appeared in the windv preview screen
6th- flipped the record mode to play and clicked play
7th - clicked capture on windv and it worked!
thanks for the help -
as ever
keen to learn..
as ever
keen to learn..
