VS9... Can no longer capture
paul85
Post by paul85 »
Using VS9, I finished a video, and whereas the program is on my C drive, all of my work had been accumulated on the E drive. I emptied all files from the E drive, and now I can no longer Capture with VS9.
I get these messages: When I pull down "New Project," it says "Unable to Make the Folder." When I try to capture anyway, it says "The specified folder does not exist or is read only."
Please advise how to restore VS9 to full operation.
Thank you.
Hi Paul,
It sounds like you deleted the folder that VS9 was using as a working folder. Try going to Preferences and check the working folder you had designated. Either change it, or just go to your E: and create a new folder with the same name as the one showing under Preferences...
Or
Under the Capture tab, you set the drive/folder where you want VS to capture to. Check to see if that folder is still present.
