Gif Animator: resizing objects in a single frame
GIF Animator, SmartSaver Pro, Plugins, Applets....
bwilderbeast
Post by bwilderbeast »
How do I resize or edit an object in one frame without it affecting the object in all other frames?
Sorry if this is a really obvious question!
rmfought
Post by rmfought »
I believe you just select the frame in the frame window at the bottom, then right click the object in the object window, and choose properties.
bwilderbeast
Thanks I'll give it a go. At the moment I can do some editing on objects copied across frames but not everything, for instance I can change their position but not size., so altering their properties could be the answer.
