Capturing footage from dvd - invalid parameter
trotsky
Post by trotsky »
When attempting to capture footage from a dvd using ULEAD VID STUDIO 9 some of the footage will not capture due to 'Invalid Parameter'. I have no idea what this means or how it can be fixed. Can anyone help please?
...and how exactly are your trying to 'capture' from the DVD -- by putting the DVD into your computer DVD drive? By copying the Files on it to your hard disk? Using the 'Insert DVD/DVD-VR' command or just changing the .vob extensions to mpg? It might also be useful to know the properties of the files you have successfully captured.
trotsky
Post by trotsky »
I am loading the DVd into the cpu and selecting the 'import from DVD/DVD-VR' option.
The properties of my successful capture are as follows:
file format - PAL DVD
file size - 452,740kb
duration - 708.960 seconds
video type - mpeg-2 video, upper field first
total frames - 17,724 frames(s)
attributes - 24bits, 704x576, 4:3
frame rate - 25.000 frames/sec
data rate - variable bit rate (max 9396kbs)
audio type - dolby digital audio
total samples - 34, 030, 080 samples
attributes - 48000 hz 2/0 (l,r)
layer - none
bit rate - 256 kbps
Have you tried the other two options I mentioned i.e. copying the files from the DVD to your hard disk and then using Insert DVD/DVD-VR from there, or else simply renaming the extension?
trotsky
Post by trotsky »
how do I change the extensions?
In Windows Explorer/My Computer, highlight the file and select 'Rename'. Leave the first part of the name but change '.vob' to '.mpg'.
trotsky
Please update your system details on your user profile page
