i ripped one dvd and opened it in UVS9, when i open it i see
"warning : nothing to output bframe decoder lag"
how can i solve this problem? i can't get output from UVS 9, please help...
UVS 9 BFRAME LAG?
Just a note of caution on the blanket condemnation, Steve. In some countries, making a back-up copy of a DVD you purchased is regarded as legal, and thus not copyright theft... though in general, you are correct.
As for the problem itself, I can't help much. That sort of message is usually associated with mpeg-4 files such as Xvid which can have bframes which are not packed correctly. Then a standard codec will not be able to open them properly. I have never had this problem, so cannot comment further than saying I believe you need to use a program such as TEMPGEnc to change the original file into one which can be read by a codec you are using e.g. Direct Show. (Steve -- I don't know if the program you mention regularly, SUPER, will do this...)
But I am not sure how much any of this relates to this specific problem because the error message came from a ripped DVD -- unless, of course, the DVD was one made with mpeg-4 files rather than the more standard mpeg-2 ones.
srknytgn
i ripped it from an original dvd to my computer, because i want it stock in my computer smaller size, it is legal in my country.sjj1805 wrote:Was this a commercially produced DVD if so it may be copy protected.
This forum does not assist with or condone copyright theft.
and heinz-oz;
it was ripped in Xvid by AutoGk
OK... so what are you using Video Studio for? If you are editing it, you might have better luck "ripping" the DVD to AVI/DV or MPEG-2 (The VOB files already contain MPEG-2 compressed video), editing the AVI/DV (or MPEG-2), and then converting it to Xvid as a final step.i ripped it from an original dvd to my computer, because i want it stock in my computer smaller size... ripped in Xvid by AutoGk
All of these highly-compressed formats (including MPEG-2) are meant for playback only. They are not really supposed to be edited or converted to another "lossy" format. You may need to get a special-purpose editor for whatever special-format you are using.
Do you have the MPEG-4 Plug-In? If not, that may help. But, the web site says the purpose of the plug-in is to make MPEG-4 files that you can play on an MPEG-4 device. It doesn't say you can import or edit MPEG-4.
Many Ulead users seem to have lots of trouble with the Xvid/DivX/MPEG-4 formats. MPEG-2 is a little better, but I've had lots of "lip-sync" problems and occasional crashing when editing MPEG-2.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
srknytgn
DVDDoug wrote:OK... so what are you using Video Studio for? If you are editing it, you might have better luck "ripping" the DVD to AVI/DV or MPEG-2 (The VOB files already contain MPEG-2 compressed video), editing the AVI/DV (or MPEG-2), and then converting it to Xvid as a final step.i ripped it from an original dvd to my computer, because i want it stock in my computer smaller size... ripped in Xvid by AutoGk
Do you have the MPEG-4 Plug-In? If not, that may help. But, the web site says the purpose of the plug-in is to make MPEG-4 files that you can play on an MPEG-4 device. It doesn't say you can import or edit MPEG-4.![]()
thanks for your kindly reply, they will help me....
