I'll do a bit of thinking and get back laterMinimum Requirements
* Intel® Pentium® III 800 MHz, AMD Athlon™ XP 1800+ 512 MB RAM
* Microsoft® Windows® 2000 SP4, XP SP2 Home Edition/Professional, XP Media Center Edition, XP Professional x64 Edition
* 900 MB hard disk free space for program installation
* DirectX® 9.0c , Windows Media Format 9, Macromedia Flash Player 7 or above
* Windows® compatible sound card
* Windows® compatible display with 1024 x 768 resolution or above
* Windows® compatible AGP or PCI graphics card (overlay support is recommended)
Unable to install moviefactory 5
- ram: 2 GB
- sound_card: Intel GMA 950
Hmm this is a bit of a puzzler. Using the 64 bit edition should be acceptable as I've just double checked the system requirements
thermosdragon
ok thanks, just for info I'm not a novice as such but not a professional either, build and maintain everything myself on several systems and run network etc. so not totally thick.
used to working in registry etc and theres no way I can get it to install, spent some time on this now and feel sure it's something to do with what I've got installed combined with win64.
As said at start, installed fine on win32 system and tried it on a second with the same programs installed (anti virus, firewall etc) as on this win64 system, all the things that may cause problems, and it installed perfect.
The only difference I can see is windows itself this system being 64 bit.
Either that or it's time for a clean windows install but everything else installs and runs fine, tried running other installs today and they all went fine, also tried uninstalling DVDMF4 and re-installing and that went fine.
wierd
thanks again much appreciated
wierd
Thermos,
I have a system designed to run 64bit, however do not. As far as I know, MF4 will not run under 64 bit, however MF5 will.
See the system specs for MF5 here: http://www.ulead.com/dmf/sysreq.htm
System specs for MF4: http://www.ulead.com/dmf4/sysreq.htm
- ram: 2 GB
See if this helps:thermosdragon wrote:downloaded the trial to have a look but get this error everytime
-5009 : 0x80040154
tried everything, ran reg fixs and bug doctor and cleaned out system but still the same.
running win64 if this is problem
http://support.microsoft.com/default.as ... -us;277964
If not click here
thermosdragon
thermosdragon
ok well thanks to everyone for their help and advice,
decided to do a re-install of windows and hey presto, all's fine, installed perfectly, still no real idea what was wrong, sounds like a corrupted windoze or similar.
Well to confirm MF5 installs and works fine on win64 (and again installed MF4 as well which also installed and worked fine even though win64 is not stated in it's requirements).
thanks again.
thanks again.
