3.1 GB at 9000 and the same at 6000. Bigger/Better with Nero
happydog500
Post by happydog500 »
When putting a video file to a disc with VS7, I used one with the setting of 9000fps. I tried again at 6000. Both said 3.1GB. Shouldn't the 9000fps be bigger?
Also, I had a 48 minute video at 8000fps. Burning it with VS It's 2.8GB on the Disc. When I burn the same file with Nero, it's about 3.5GB. Looks way better also.
Is there a way to get a file bigger when putting it on a disc with VS? Maybe that will help it be as good quality as Nero. When I have almost an hour video at 2.8GB with a 4.7 Disc, I think I may be wasting quality.
Thank you,
Chris.
DVDDoug
Moderator
Post by DVDDoug »
There's nothing wrong with your logic... A 9000kbps file should be bigger than a 6000kbps file.
Unless the 9000 was a variable bitrate (VBR), with an average bitrate of 6000.
Or, is your source-file MPEG? If you are starting-out with a 5000 kbps MPEG file, the encoder might be smart-enough keep the lower bitrate, since it can't improve the existing quality/detail.
Higher bitrate = higher quality = more disc space = lower compression = less playing time.
Lower bitrate = lower quality = less disc space = higher compression = more playing time.
Here's a link to a Bitrate Calculator.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
Please also see the 7th post down here:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=11923
happydog500
sjj1805 wrote:Please also see the 7th post down here:
I did this and it said the same size. That is why I posted in the first place, it didn't change anything when I changed the settings.
It is MPEG to start. I think my software I'm using is set at 8000 constant rate.
VS7 doesn't have the feature to make it fit.
Thanks for replying,
Chris.
