Problems with Burning DVDs in MF5
mastermusic
Post by mastermusic »
Hi guys
I'm new to this form. However' my name is Kevin and I am avery old user of ulead products.
I just purchased the MF5 15 min. ago and installed it.
MF5 does not burn my DVD. I have sent a request for help to support.
It reaches the Video\audio multiplexing and the crashes...
Does anyone know why this happens??? . I have also DVD workshop 2 and it never happed there. What should I do??? please help me.
Kevin
as you've only just installed it the installation may have gone wonky.
Run the installer again and you will find a repair option
mastermusic
DvdMF5 burning problems
Sorry,
I tried to repair the installation.
The same tihing happens.
Video/Audio multiplexing reaches 37% and the program freezes.
I dont know what to do.
Kevin
maddrummer3301
Post by maddrummer3301 »
Kevin,
You do need to reboot the computer after installation of MF5.
Use the export feature from the timeline to create your video files.
Then import them as compliant dvd videos into the timeline so MF5
doesn't have to render them.
It sounds like the error is in the video creation/rendering and not the actual burning process going by your description.
The above statement "Video\audio mutiplexing" refers to the creation of the temporary VIDEO_TS folder on the harddisk that will be burnt to a dvd in the next process.
Do you have enough free space on your assigned working folder? (Preferences F6 key).
What are your source files? Are they mpeg2 files or divx(uh...oh), or dv.avi?
MD
mastermusic
Well, I do all my video editing in Viodeostudio8, Studio9+(pinnacle) and recently also in Mediastudio8. I only import the mpeg2 videos into mf5 to authorize them to DVD and Yes, I have 79GB of space in my working folder. Last night I tried to burn a dvd only with ONE video and it worked, so... is it really the mpegs???what should I do in this case. I can burn them all in DVD workshop. Should I ask for a refund on the MF5???
I tried everything but nothing seems to work. At first I thought that the content was not good. The menus were giving trouble but now I dont think it's them.
Please advise.
Kevin
Video_guy
Movie Factory 5 DVD Disc Burning Problem Solved
Post by Video_guy »
I too had problems burning DVD's in Movie factory 5, after been a long time user of version 3 & 4 and never having a problem.
I was getting the message DVD drive is busy been used by another appliction, just as the data was about to be burnt to disc. after trial and error, I found out that if i shut down the Moviefactory 5 "Intuitive Quick-Drop" mini desktop applet that this solved the problem and everything worked fine.
Chris.
mastermusic
Hi Chris,
Well I tried that too and no way ... Its the same.This is really getting frustrating and I dont know what is the problem. I tried every possible way,but nothing seems to work.
Kevin
maddrummer3301
If you have "Quick Drop" running in the background which should be an icon on the taskbar as an active running background process then "Right-Click" on it and close it. That will remove it from resident memory and not lock the drive for packet writing.
To stop it from loading when windows starts right-click on it and select "Option"s and uncheck the box that says "Load when windows starts" etc.
Maybe quick-drop is interfering with the drive.
Or, it is a bug.
MD
htchien
operating_system: Mac
Post by htchien »
I think the problem might be the source files. Can you list the properties of the source files and the project properties in DVDMF 5?
Also, how many codec packs do you install in the system?
Thanks and best regards,
H.T.
Ted (H.T.)
mastermusic
I do not think that the problem is with the source files since these were made in Mediastudio pro 8 and besides that, ALL the source files are MPEG2 and CAN burn DVDs in DVD workshop!!! so why doesnt it burn in MF5???
As for codec packs... whre can I find all the installed codec packs and what am I looking for???
Kevin
OzzyDownunder
Post by OzzyDownunder »
Go to this sight and download a program called "SHERLOCK - The Codec Detective!" and this will find all installed codec. Hope that may help?
http://www.updatexp.com/sherlock-codec-detective.html
Graham
OzzyDownunder
mastermusic
I have done this. I downloaded Sherlock and found out that the Ulead codecs are Broken. I reported this to Ulead but they doent seem to understand what "Broken" means.
I am losing my dear patients...
If there is anyone that can help[ please do so.....
Kevin
maddrummer3301
Have you tried to create a dvd harddisk folder instead of burning the dvd?
I don't know if this is relevant but when you burn a dvd in MF the program builds the dvd structure on the harddrive prior to burning. The location of the dvd structure is a temporary directory under the working folder. It's removed from the harddisk after burning the dvd.
First, the program multiplexes the video/audio streams into vob's, then writes out the ifo information, then burns the dvd folder from the harddisk to a dvd.
So the program isn't burning "On The Fly". It creates the dvd structure on the harddisk first so a steady stream of data can be sent to the dvd when it's being burnt.
It could be a bug/flaw, you posted that WS2 works so somethings up somewhere's.
I would try to simulate WS2 in MF5 by unchecking any fancy menus, no transisitons, no added audio, no motion menus etc.
It could be something up with the new menuing enhancements.
But, to me going by your post it's in the video/audio mutiplexing stage which is actually the creation of the dvd structure in the temp directory.
MD
maddrummer3301
mastermusic,
The term with respect to that program means the program cannot find the file.
After you run Sherlock click on the files that do not report errors and in the screen to the right will be the location of that file.
Sometimes when you un-install a program this will happen.
It doesn't always mean that's what is wrong.
MD
mmponline
Post by mmponline »
According to me, this is a fault / bug in MF5 along with several others, as MF 4 (after SPs) handles this without any problems.
I've listed several other MF5 faults in previous posts, but the response is silent. Also sent it to ULead Support. They seem to have a standard "Uninstall / Re-install response that goes out nowadays to all first querries. Whether it's due to the bad releases or trying to buy time for SPs to come out, I don't know.
I've also decided not to buy any Ulead program before the first SP is out, as the new programs (Like MF5 and MSP8 - Even had an interim Hotfix) are shipped with to many faults. Not good for the try before you buy concept. Ulead will be losing lots of potental buyers.
I'm just hoping for some SPs in MF5 and MSP8 soon.
Stephan - www.mmponline.co.za
Ulead products:
MSP8, PhotoImpact10, MF4 and 5, Cool 3d Production Studio, Photo Explorer 8.5
